Date:    4-6-2012
Number of Hours:    2.34
Brief Description:    Continuing with the front spar assembly
Worked on tapering the front spar reinforcement angle as well as the splice angle. I then bent the two parts as shown on the plans to the 6 degrees as instructed. I had to go to the airport and use Joes bandsaw and mill for the cutting work then did the finishing work on my thumb grinder, oh, I mean my bench grinder.
I then trimed the the front spar flange as the manual/plans instructed cut the notch in both HS-702 front spar parts and bent it the 6 degrees it called for.
Another day down.
