Date:    12-26-2006
Number of Hours:    3.00
Brief Description:    Install pitot tube and airleron push rods
The plate to adapt the pitot tube assembly to the bottom of the wing needed tobe fabricated. The pitot tube assy was attached to the plate. The four screw holes to attach the assembly to the wing need to be enlarged.The long and short airleron push rod assemblies were attached to the bell crank.. Real tight.
