12-8-2006 |
3.50 |
Prepping Right rib #9 for rivetting |
Right rib #9 was prepared for assembly, The support rails were located and drilled to size. Then the bell crank was mounted on the opposite side. The bell crank was drilled to size. Lastly, the four clips were fabricated and mounted in place. The holes were drilled to size. The rib parts were deburred and the rib assembled ready for rivetting. |
