3-22-2015 |
2.05 |
Wings 4 |
Fitting wing tip initially isn't the easiest task, especially when the instructions relate to the previous type of wing tip. Problem is there is no rib at the end so the metal doesnt hold shape. However after speaking to someone I made a temporary rib using the nose rib from the other wing as a template and it makes the job so much easier. Wing tip fits in place in 5 minutes. Most of time spent trying to fit tip before template used |
