9-29-2014 |
8.00 |
Ailerons |
Located all parts deburred and cleaned up rough edges, Primed sections that will be joined Next steps virtually copy each other naturally enough right and left, Only issue with end of innner aileron some holes not drilled in rib, first time. Only need to complete solid rivets, have ordered a rivet squeezer rather than use pliers. I wasn't happy with the result so hopefully rivet squeezer will do a better job. |
