Date:    7-29-2007
Number of Hours:    3.00
Brief Description:    Finished the rudder and started the stab
After letting the epoxy cure for twenty four hours with great results, I finished it off with rivets. I then put it aside until my rivet squeezer arrives. The trailing edge uses solid rivets. So on I went to assembling the stabilizer frame. That went well until I discovered I missing a couple of brackets. I'll have to look into that before I can go any farther.
