7-31-2009 |
1.00 |
Match drilled the ribs to the wing spars |
All the ribs in the left wing (except the tank ribs and the most inboard leading edge rib) were match drilled and clecoed. The missing holes in the three inboard W-711 ribs were drilled using the spar as the guide. I am going to deviate slightly from the shop guide at this point. Rather than removing all the ribs, deburring, dimpling, priming, reassembling and riveting, I am going to continue with installing the skins and do all the match drilling before breaking everything down. |
