5-24-2009 |
0.50 |
Mounted right elevator and drilled horn |
Mounted the right elevator, inserted the hinge bolts, and clamped the elevator in trail with stabilizer. Using the drill bushing previously fabricated, drilled the elevator horn to #40. Once the elevator was removed, the hole in the horn was final drilled to 1/4" to accept appropriate bolt. |
