9-14-2008 |
1.00 |
Fastened the hinge brackets to the rear spar |
Riveted the HS-412PP and HS-413PP hinge brackets to the rear spar. Tested the Pittsburgh brand torque wrench prior to tightening bolts on center bearing hinge bracket. Bolted the HS-411PP center bearing hinge bracket to the spar per torque value chart in section 5. |
