Date:    10-20-2008
Number of Hours:    0.70
Brief Description:    Continue initial assembly of left elevator
Removed the clecos holding the root rib (E-705) to the spar and then clecoed/drilled the elevator horn (WD-605-1-L) to the spar and root rib.
Clecoed and final drilled the trim spar (E-606PP) to the root rib (E-705)..
Match drilled the E-701-L skin to the understructure.
