Date:    8-24-2008
Number of Hours:    1.50
Brief Description:    Preliminary rear spar assembly
Located the holes for attachment of the main ribs (HS-708) to the rear spar and enlarged to #21 (see rear view).
Clecoed the elevator hinge brackets (HS-412PP and HS-413PP) to the rear spar assembly and final drilled to #30.
Assembled and match drilled the center hinge bearing assembly to the rear spar assembly (HS-411APP, HS-411BPP and VA-146). Disassembled the center hinge bearing assembly, deburred and riveted together using AN470AD4-5 rivets per instructions.
Clecoed the center hinge bearing assembly (HS-411) back to the spar and final drilled the bolt attachment holes to #12.
Marked all parts in the horiz stab rear spar assembly so they can be returned to their proper position at final assembly step.
