Date:    5-2-2016
Number of Hours:    3.00
Brief Description:    Rubber seals on side baffles
The seal material was cust and installed on the side baffles. You can see from the ppictures, however, some additional cutting will be require to make the rubber mate to the cowl smoothly. There will also have to be more trimming when the cowl is installed.
