Date:    10-28-2015
Number of Hours:    3.00
Brief Description:    Miscellaneous small tasks
After talking to another builder regarding canopy stops, I decided to move the stop located at steel weldment that supports the back of the pilot's seat. I moved the stop back aboput eight inches so the steel bar can be used as a seat when entering and exiting the cockpit.
I also filled the trailing edge of the wingtips with polyfil. This improves the cosmetics and will help keep wasps out.
Finally, I shortened the rear throttle arm. Again, this was done for cosmetics. The stock arm length was just too long.
