Date:    7-15-2015
Number of Hours:    3.00
Brief Description:    Cowl baffles
Once the cowl baffles were fitted and "glued" into place, some glass layups and filler were added to smooth the edges of the glass components. This was done to create less turbulent air flow in the intake area.
These layups and filled areas still require sanding. I will also have to apply heat reflective foil and/or high temp paint.
