8-24-2015 |
3.00 |
Riveting bottom outboard skin port wing - Part 3 |
Finished squeezing the final rivets on the bottom of the port wing. Also had to drill out 10 rivets that were incorrectly installed in the most inboard rib. These holes will probably get nutplates to attached fuselage to wing fairings. Matched drilled and machine countersunk the trailing edge holes in the bottom skin for attachment of the flap piano hinge. Moved the port wing to the new cradles and got the starboard wing in the cradle for riveting. |
