8-31-2014 |
1.00 |
Rerouted Archer antenna coax and terminated |
While installing the flexible pitot tubing I rerouted the coax cable for the Archer antenna to exit the fuslage a bit farther back. This allows the coax to be connected to a female BNC connector (bulkhead type) facing forward. The coax coming from the wing root will have a matching male connection. I had to fabricate a small L shaped bracket to secure the bulkhead BNC connector. You can see it in the photo below help by a cleco. I still need to attach the BNC connector to the coax and mount it on the bracket. I plan to order a couple bulkhead BNC connectors from Allied Electronics. |
