Date:    6-10-2014
Number of Hours:    1.00
Brief Description:    Fabricate & install exhaust pipe brackets - Part 2
I have included pictures of the mounting brackets from some different angles. I also had to remove the crankcase breather tube from the engine and cut a bevel in the lower end. The tube was reinstalled just above the port exhaust pipe and outboard enough to give plenty of clearance from the exhaust piper brackets. Looks good, I think.
