6-13-2013 |
4.00 |
More wire clean-up (beneath cockpit) |
I think the fuselage wiring with the exception of firewall forward connections is 99.9% complete. I finished the day relabeling the wires connected to the terminal strips beneath the front cockpit. These strips are where all the stick wires will be connected. As a reminder, the stick switches will control the starter, flaps, pitch and roll trim, push-to-talk, autopilot connect/disconnect, and the fuel boost pump. The rear stick will have flaps, pitch and roll trim, and push-to-talk. The other functions present on the pilot's stick will be inop. In addition, the pilot will have a toggle switch on the panel allowing the rear stick to be disabled entirely. |
