Date:    6-12-2013
Number of Hours:    6.00
Brief Description:    More wire labeling and clean-up
Today, I continued the relabeling of all the wiring and removal of the old "flag" type labels. I have included some additional pictures below of the autopilot terminal strip, starter and boost relays, and a couple ground posts.
The autopilot strip is missing three connections on the lower right side. These wires go to a selector switch that allows me to select GPS input from two sources to the ADI Pilot II instrument. I plan to add a portable Garmin 796 later that will be hardwired into the aircraft and attached via a Ram Mount.
