8-15-2012 |
2.00 |
Floor covering (vinyl) front cockpit |
I cut the floor mats for the front cockpit and prepared the floor for gluing the mats in place. Since the floor was primed and the area to be covered is about 24"x14" I did a little further testing to see if I could do the install without removing the primer. Bottom line, the 3M 77 adhesive probably works good enough but I found a 3M 80 made especially for vinyl and rubber. A test indicated it provides a little better bond. |
