Date:    11-10-2019
Number of Hours:    1.50
Brief Description:    Made up aand secured side mount brackets
Two side mount brackets had been lost in transit so I made them from 25 mm Angle aluminium and secured them in place. I also re-glued the centre support piece on the rear instrument panel from the instrument support panel to the rear front cockpit seat back.
I cleaned the areas, lightly sanded the woodwork, and wet and dried the aluminium angle. Prior to fitting I cleaned the areas and angle. After applying the adhesive expoxy I secured the angle pieces aith tape to hold them in place while the epoxy set and I clamped the centre piece.
