7-8-2012 |
14.00 |
Machining axel attach brackets |
It took two different days of measuring and machining to come up with this axel attach fitting for the landing gear. The strut attaches through the vertical hole and the axel bolts to the round 4 bolt pattern. Tim is bringing the measurements and tracings of the part home to input them into Alibre. The next fitting should only take a couple of hours to machine. |
