I started the heater in the shop around 7:30 as it was only 32 outside and I wanted to do some prosealing. About 8:30 I got started and it was 70 in the shop. Good temp for working. Anyway, I got everything ready to rivet some ribs in the tank and then mixed up 12 cc's of proseal. I had already fay sealed them so this was fairly easy. I got all the bottom rivets set and sealed along with the outboard rib. It warmed up nicely out so I quit at noon and went and played golf. Hopefully tomorrow, I'll finish sealing the ribs and fillet them with proseal and work on the access plate. Reva doesn't have to work tomorrow so it should be a very productive day.
