Today, after about 2 weeks off, I returned to work on the left tank. I fabbed the vent line and installed the bulk head fitting for it. Also riveted in the inboard tank attach bracket. I prosealed in the fuel sender in the access plate along with the bulk head fitting for the fuel pick-up tube. With the proseal that was left, I covered a couple of places that looked a little suspect. I then went to work on the leading edge for the left wing in anticipation of finishing the tank and mounting it. I did some research on the landing lights that go in the most outboard bay of the leading edge and installed the nutplates on the splice strip on the inboard edge of the leading edge. I then removed it from the spar to deburr and countersink it. I'm going to try to get several parts ready to prime next weekend as it's too dark outside when I get home from work.
