Deburred all the holes I had match drilled and riveted all the ribs to the main spar. I t was quite a challenge by myself but once I got the air pressure set correctly, for the long rivets it wasn't too bad. My back was hurting when I got done from all the bending over. Sometimes I wish that I had built my main bench taller than 36". I'll look over the rivets tomorrow evening to make sure they are all okay.Point to remember: 2x gun at 65# for the AN 470 rivets. It can be a little less for the shorter ones.
