1-1-2016 |
0.00 |
Rudder mods Trim |
Decided to add the capability for trim using a hinge attached to the rudder TE and actuated by a Ray Allen servo. To allow for this, I need to route wires to the area where the servo will be located. Tim Olsen did the following write-up http://www.myrv10.com/N104CD/upgrades/20071104/index.html Ordered parts from Van's to build an access plate and doubler. Wire will be sheathed in braided nylon sheath. This will be offset from the rudder skin by wire-tie (same as VS parts). This run will terminate in a CPC that will be common with the lighting for the tail. CPC ordered from mouser. |
