Date:    4-21-2016
Number of Hours:    8.00
Brief Description:    Flaps and VPX
Hooked up the Flaps and the Flap position sensor. Powered up the VPX and ran the configurator. Got everything entered and set the Flaps so that they will reflex and with one tap on the flap handle they will move to the next position and stop.If they are full down they will come all the way up to the neutral position and stop unless at some point I tap the down switch, in which case the flaps stop moving.
