Date:    1-5-2017
Number of Hours:    6.00
Brief Description:    Multiple items
Cut the excess filler from the canopy. When it fully cures then I will sand. Weighed the wheel pants to add to the weight and balance done the other day.Removed the wing tips. Replaced the nutplates that had screws broken off in them. Replaced the wing tips tapping the holes where the screw went in too hard.
Installed the wing tip lights plexiglass coves tapping the holes as required. Used locktite on all the screws used to hold on the plexiglass.
Installed the locator beakin antenna.
