Date:    4-7-2016
Number of Hours:    2.00
Brief Description:    UP MICRO SWITCH
1 Swing the nose gear to the fully retracted position.
2 Find the loction for the switch that will cause the switch to close when the nose gear is retracted.
3 Match drill the switch to the uostop brce then attach using the hardware provided with the switch.
4 Connect the switch to the electricl harness.
5 Lower and retract the nose gear several times to test the action of the switch.
