Date:    4-7-2016
Number of Hours:    4.00
Brief Description:    GEAR DOORS SPRINGS
1 Drill a small hole on each side of the gear door link arm . The hole shold be just large eenough to accept one end of the spring.
2 Attach the spring brackets tothe door hinges. Replace the existing rivet.
3 Attch the springs to the brackets and the swing arm.
4 Extend and retraact the nose gear to test the operation of the springs. Adjust the springs or attachment of the brackets as required.
