4-7-2016 |
4.00 |
WING GROUNDING |
The fuel filler port flange of both wings are connected through studs and electrically conductive paint to grounding studs in the wing tips and to the static wicks. The gronding studs in the wing tips are connected to a ground wire in the wing electrical harness that then connects to grounding studs in the fusalage. These grounding studs are the connected to a ground wire in the fusalagw electrical harness. Electrically conductive pint is used to ground the fuell filler port to the wing grounding stud.Ref to chapter 5 wing for paint informtion. |
