Date:    2-11-2016
Number of Hours:    16.00
Brief Description:    INSTALLING THE FLOORBOARDS
MAKE THE FLOORBOARD INSTALLATION JIGS USING THE PROVIDED THE TEMPLATES.
1 CUT THE JIGS FROM 3/4" TO 1" THICK PLYWOOD. IT WILL BE NECESSARY TO BEVEL SOME OF THE CORNERS AND EDGES.
2 USE THE JIGS TOCREAT CARBON FLANGES WHICH SUPPORT THE FLOORBOARDS IN THE PROPER POSITION.
3 TRIM THE FLOORBOARDS USING THE PAPER TEMPLATES AND THE JIGS, TO FIT THE FINAL LOCATION.
4 DRILL HOLES USING THE PAPER TEMPLATES , MATCH DRILLING THE HOLES.
5 PUT HARDPOINTS IN THE FLOOR PANELS WHERE ANY ADDITIONAL SUPPORT NEAR THE CENTRE LINE.
FLOORBOARDS SHOULD BE SECURED TO THE FUSALAGE USING 4 BID LAYUPS 2: WIDE AND CUT THO LENGTH AS REQUIRED.
