2-11-2016 |
6.00 |
INSTALLING SHEARBOX ACCESS PANELS |
ACCESS PANELS ARE INSTALLED ON THE FWD AND REAR SHEARBOXES 1 DRILL THE MOUNTING HOLES FOR THE REAR SHEARBOX ACCESS PANEL ( 284-0151) USING THE TEMPLATE 426-0235 CLEARANCE HOLES FOR #8 SCREWS USING A #19 DRILL BIT. 2 CLEAN THE EDGES OF THE PRE CUT HOLES 3 CLEAN UPTHE BOTTOM OF THE PANEL. MAKE SURE THE CORE CLEARS THE HOLE CUTOUT, REMOVE NY EXCESS FOLDS OF MATERIAL. ENSURE PANEL FITS FLAT TO THE SHEARBOX. 4 FIT THE PANELTO THE SHEARBOX OPENING WITH THE PANEL RESTING IN THE JOGGLE AND EQUALLY SPACED ALL AROUND. 5 USING A #19 DRILL BIT , MATCH DRILL THE HOLES THROUGH THE PANEL, AND THE JOGGLE ON THE FLANGE. 6 INSTALL THE NUTPLATES. USE A NUTDRILL TOOL TO DRILL THE RIVET HOLES FOR THE NUTPLACE. THIS PRODCEEDURE IS USED FOR THE FORWARD AND AFT SHEAR BOX PANELS. |
