2-9-2016 |
4.00 |
HYD PUMP MOUNT |
THE HYD PUNP MOUNT IS NOT MOUNTED TO THE CENTRE PARTION DUE TO THE AUX FUEL TANK INSTALLATION. 1 MANUFACTURE A MOUNT AND LOCATE IN THE AFT BAGGAGE COMPARTMENT4 3/4 INCHES AFT OFF THE AFT SHEAR BOX, 2 " LEFT OFF THE AIRCRAFT CENTRLINE. 2 BOND THE MOUNT TO THE FUSALAGE USING HYSOL, AND ROUND FLANGES. 3 USING THE HYD PUMP AS A GUIDE, MARK AND DRILL THE HOLES FOR THE HYD PUMP. ENSURE THE PUMP IS NOT TOUCHING THE BOTTOM OF THE FUSALAGE. REFER TO CHAPTER 11 HYD SYSTEMS, SECTION 11.2.C HYD RESERVOIR AND PUMP UNIT 4 CHECK THE CLEARNCE OF THE HYD PUMP TO THE ELETATOR TORQUE TUBE. |
