2-9-2016 |
10.00 |
ELT MAG 3100-MAGETOMETER |
1 MAKE N 8"X 4"X 2" BLOCK OUT OF MEDIUM DENSITY FIBERBOARD ( MDF) OR NON-POROUS WOOD. COVER THE BLOCK WITH CLEAR TAPE SO THE CARBON LAYUP CAN BE REMOVED AFTER CURING. 2 MAKE A 6 BID CARBON LAYUP AT 45 OUT OF 12" X 8" SHEETS 3 WET UP THE 6 BID ON THE TABLE THEM LAY IT OVER THE BLOCK. 4 AFTER CURING, REMOVE THE PART AND CUT THE PART TOMAKE TWO SHELFS AS SHOWN 5 LEVEL THE AIRCRAFT. 6 ENSURE THE SHELFS ARE LAVEL FORE ANF AFT, AND SIDE TO SIDE.. BOND TO THE FUSALAGE USING HYSOL, HOLD THEM IN PLACE WITH CLECO FASTENERS UNTIL THE HYSOL CURES. 7 INSTALL THE ELT AND OPTINIONAL MAG 3100 USING THE MANUFACTURERS INSTRUCTIONS. |
