2-9-2016 |
8.00 |
RHINO 9700 NOVALAC PAINT |
RHINO9700IS SED TOCOAT THR FUSALGE WITHIN THE COCKPIT PRESSURE VESSEL ONLY, TO PROVIDE CHEMICAL AND ABRASION RESISTANCE,FROM ACCIDENTAL SPILLS OF HYDRAULIC, BRAKE AND SUEL FLUIDS 1 ABRADE THE SURFACE TO BE COATED TO ACHIVE A 5 MIL PROFILE. 2 REMOVE ALL CONTAMINANTS SUCHAS DUST , OIL OR DIRT. 3 MIX , APPLY AND CURE THE COATING IN ACORRORDNCE WITH THE MANUFACTURERS INSTRUCTIONS, EXCEPT AS OTHERWISE INDICATED. 4 APPLY THE MIXED PRODUCT BY BRUSH OR ROLLER TO ACHIVE 15 MILS THICKNESS 5 ONCE THE FIRST COAT HAS TACKED, BUT NOT FULLY CURED, APPLYAN ADDITIONAL 15 MIL COATING. 6 ALLOW THE MATERIAL TO CURE FOR A MINIMUM OF 48 HOURS BEFORE EXPOSURE TO ANY CHEMICALS. THE PRODUCE WILL COTINUE TO CURE FOR 7 DYS TO FULLPROPERTIES. |
