9-25-2014 |
4.00 |
MAIN GEAR UP HARD POINT |
WHEN THE GEAR IS UP, THE TRAILING LINK WILL MAKE CONTACT WITH THE INSID OF THE UPPER WING SKIN. TO COMPENSATE FOR THIS, A HARD POINT NEED TO BE INSTALLED. CUT A 3 " DIAMETER CIRCLE FORM PHENOLIC BLOCK.. LOCAT WHERE THE HRD POINT IS REQUIRED. dECORE THE WING SKIN IN THAT AREA. AND CREAT A HARD POINT. APPLY A 4 BID CRBON LAYUP, STAGGERING EACH LAYUP BY 3/4" |
