5-16-2015 |
8.00 |
MATING THE WING TO THE FUSELAGE |
BEFORE INSTALLING THE WING FOR THE FIRST TIME OR AFTER RETURN FROM PAINT. FLUSH OUT EACH WING FUEL TNK WITH 5 TO 10 GALLONS OF FUEL. DRIN FUEL AFTER. SEAL ALL PENERTRATIONS BETWEEN THE SHEARBOX ANS THE WING SPAR. INSERT SPARS OF THE WING ONTOTHEIR RECEPTACLES IN THE FUSELAGE. SLIDE WING AS CLOSE AS POSSIBLE. STARTING A MOST INTERIOR PIPING STRAT MAKING THE CONNECTIONS ENSUEING ON DEBRIS ENTERS THE SYSTEMS. PLUG ELECTRICAL WING CONNECTION. SLIDE THE WING IN PLACE, MATING WING TO FUSELAGE. SLIDE BOLT INTO PLACE USING BULLET ON THE END. ONCE BOLT IS IN PLACE REMOVE BULLET. TIGHTEN ,NUTS UNTIL THE WASHERS CONTACT THE SHOULDER OF THE BOLT (100-00070 WASHER (AN960-1216) NUT (AN364-1216A) |
