5-16-2015 |
2.00 |
WING FUEL VENT |
INSTALL WING FUEL VENT INTO THE WING TIP THROUGH THE ACCESS PANEL. CONNECT THE CHECK VALVE TO THE FUEL TANK (545) WITH FLOW LINE TOWARDS THE TANK. CONNECT T FITTING (AN824-6D) TO THE CHECK VALVE. TUBING 5052-.375/.035 AS REQUIRED. FOR CORRECT ALIGNMENT. NUT COUPLING (AN818-6D AND SLEEVE (AN819-6D) AS REQUIRED FOR CORRECT ALIGNMENT |
