5-16-2015 |
6.00 |
BRAKE MASTER CYLINDER |
THERE ARE FOUR BRAKE MASTER CYLINDERS. ATTACH BODY OFF MASTER CYLINDER TO THE FRAME OF THE PEDAL ASSEMBLE. THREAD THE ROD END INTO THE END OF THE BRAKE MASTER. THE FARTHER IN THE ROD END IS THREADED IN THE MORE THE RUDDER PEDAL WILL TILT FWD. TOWARDS THE FIREWALL. ADJUST PEDAL AS DESIRED. ENSURE THERE IS A MINIMUM12 THREAD ENGAGMENT. |
