Date:    5-16-2015
Number of Hours:    4.00
Brief Description:    RIGGING THE RUDDER
CLAMP THE RUDDER IN NEUTRAL POSITION.
THREAD CLEVIS OF TURBUCKLES SO THERE ARE FOUR THREADS SHOWING.
POSITION PEDALS SO THEY ARE NEUTRAL.
THREAD THE CABLE THROUGH A NICOPRESS SLEEVE (18-3-M) THE CABLE THIMBLE AND THE TURNBUCKLE EYE AND FORM A LOOP AT THE END OFF THE RUDDER CABLE.
THEM THREAD THE END BACK THROUGH THE NICOPRESS SLEEVE. ( DO NOT REMOVE ANY EXCESS CABLE AT THIS TIME)
PULL THE LEFT SIDE CABLE AS TAUT AS POSSIBLE. HOLD THE CABLE TENSION AND NICOPRESS SLEEVE IN PLACE USING A CLAMP.
REPEAT THE PROCEDURE FOR THE RIGHT SIDE CABLE
