Date:    5-16-2015
Number of Hours:    6.00
Brief Description:    RUDDER TAIL CAP
RUDDER MUST BE INSTALLED PRIOR TO INSTALLING THE TAIL CAP.
POSITION THE RUDDER IN THE NEUTRAL POSITION.
CLAMP THE RUDDER IN THE NEUTRAL POSITION.
ASSEMBLE THE TWO HALSE OFF THE TAIL CAP AND ATTACH WITH CLECO FASTENERS.
JOINT THE TWO HALF TOGETHER WITH FLOW. ENSURING THE GAP IS FLUSH WITH THE TOP OFF THE RUDDER AND SHOULD HAVE A MAXIMUM GAP OFF 1/8 INCH.
ONCE BOND HAS CURED, REMOVE ANY EXCCESS FLOX.
INSTALL NUTPLATE INTO THE CLECO HOLES.
CLEAN THE TRAILING EDGE OF THE CAP TO CONFORM TO THE RUDDER.
