Date:    4-4-2016
Number of Hours:    4.00
Brief Description:    CONDENSER INLET VENT HOLE
The condenser inlet vent hole is located on the left side of the fusalage anf aft of the pressure bulkhead.
1 Locate and mark the location of the plenum and the inlet vent hole. rf to fir 16.2.a.1
2 ref to fir 16.2.A.5 condenser inlet vent template for a full size pattern of the inlet vent hole.
3 Cut the condenser inlet vent hole in the fusalage.
4 Cut an ellipse shpe piece of screen 9850-0023) that is approx 1/8 larger than the inlet vent hole. On the inside of the fusalage, centre the scree over the hole and bond it in place using hysol.
5 Reinforce the vent hole with two layers of 4 bib carbon fiber.
