4-4-2016 |
4.00 |
HVAC DRYER |
The dryer is mounted aft off the rear preeusre bulkhead on the right side off the fusalage. 1 Make a mounting braket for the dryer. The braket shown ( fig 16.2.H.2 0 ) is made up of layup shaped as required and bonded to the fuslage using Hysol or Flox 2 Locate the mounting braket so the installed it will not interfere with the elevator push pull tube or the other components located in the area aft of the pressure bulkhead. 3 Installthe dryer with its axis vertical and the inspection window up . 4 Attach the dryer to the mounting braket using a clamp ( 145-0013) |
