4-4-2016 |
4.00 |
FIREWALL CONNECTIONS |
1 Install the expansion valve on to the evaporator coil. note all lengths are approimate. Adjust the lengths as required 2 Attach the vinyl tubing between the evporator drain fittings and the stainless steel tubing.Secure the tubing to the drain fittings and the tee using worm drive clamps. |
