Date:    4-1-2016
Number of Hours:    1.00
Brief Description:    INTRODUCTION
IN THIS CHAPTER YOU INSTALL ALL FOUR SEATS IN YOUR EVOLUTION. THIS PROCESS INCLUDES INCORPORATING SLIDER MECHANISMS FOR ADJUSTING THE PILOT'S AND CO-PILOT'S SETS. IN ADDITION, YOU WILL INSTALL THE SEAT BELT ANCHORS FOR THE SHOULDER HARNESSES.
STEPS TO COMPLETION
FRONT SEATS:
* ATTACH THE SEAT BELT BRACE AND BRACKE TO THE MOUNTING PLATES.
* LOCATE THE SEATS ON THE FORWARD SHEAR BOX AND DRILL ATTACHMENT HOLES.
* MAKE SCREW AND BOLT HARDPOINTS IN THE SHEAR BOX.
* MAKE THE SEAT BRACE RELEASES.
* INSTALL THE MOUNTING PLATES.
* INSTALL THE SEAT BELT SHOULDER HARNESS ANCHORS.
* INSTALL THE SEATS.
REAR SEATS:
* INSTALL THE MOUNTING BLOCKS.
* INSTALL THE SHEAR BOX REINFORCEMENT FLANGES.
* INSTALL THE REAR SEATS TO THE MOUTING BLOCKS.
* INSTALL THE SEAT BELT SHOULDER HARNESS ANCHORS (OPTIONAL).
QUANTITIES INCLUDE ALL MOUNTING HARDWARE FOR THE SEATS.
INSTALLATION NOTES
- the front seat mounting plates and the rear seat mounting blocks cannot be installed, or removed, if the wings are inserted into the fuselage.
- all hardware that installs inside the shear box needs to be low clearance.
- any location where you cannot use locking hardware, use Loctite.
