Date:    4-1-2016
Number of Hours:    5.00
Brief Description:    PREPARING FOR SEAT INSTALLATION
1 LOCATE AND DRILL THE BOLT HOLES FOR THE REAR SEAT MOUNTING BLOCKS. LOCATE THE BOLT HOLES USING TEMPLATE (010-0015)
2 EXCEPT AS OTHERWISE INDICATED, SHEAR BOX BRACES AR CENTRED UNDERNEATH EACH SEAT MOUNTING BLOCK AND POSITIONED SO THAT THE ATTACHMENT BOLTS
FOR THE MOUNTING BLOCKES PENERTRATE THE BRACE FLANGE. REF TO FIR 14.2.I.3
3 USING HYSOL , BOND THE TWO SHEAR BOX BRACES UNDERNEATH EVERY SEAT MOUNTING BLOCK.
4 AFTER THE HYSOL HAS CURED RE-DRILL THE HOLES FOR THE MOUNTING BLOCKS.
5 AT THE THREE LOCATIONS WITHIN THE SHEAR BOX, ADDITIONAL BRACES ARE INSTALLED TOTHE UNDERSIDE OF THE SHEAR BOX AND AGAINST THE REAR WALL.
6 POSITION THE MOUNTING BLOCKS WITH THE FLANGE SIDE OF THE DOVETAIL RECEPTACLE FACING AFT.
7 ATTCH TH MOUNTING BLOCKS TOTHE FLOOR USING SCREWS ( MS24694-S51) WASHERS ( AN960-10L) AND LOCKNUTS ( AN364-1032A)
8 TORQUE THE NUTS 20-25 IN-LBS.
