3-31-2016 |
4.00 |
BRAKE LINES. PARKING BRAKE TO THE WINGS |
ALUMINUM TUBING IS USED TO CONNECT THE PARKING BRAKE TOTHE BRAKE LINES IN THE WINGS. 1 ALUMINUM TUBING (1/4 DIA X 0,35 WALL. 5052-0) IS USED FOR THE BRAKE LINES FROM THEOUTLET PORTS OF THE PARKING BRAKE VALVE TO THE BULKHEAD FITTINGS IN THE LEFT AND RIGHT SIDES OF THE FUSALAGE. REF TO FIG 13.2.E.1 2 MEASURE THE LENGTH OF TUBING YOU WILL NEED INCLUDING THE EXTRA TO ALLOW FOR EXPANSION AND ROUTING AROUND FUEL AND HYDRAULIC LINES. 3 SLIDE NUT ( AN818-4D) AND SLEEVE ( AN819-4D) AS REQUIRED OVER THE TUBING PRIOR TO FLARING.. THIS MUST BE DONE FOR EACH END OF THE TUBING. 4 FLARE THE ENDOF THE TUBING. REF TO CHAPER TO FOR FLARING METHODS. 5 POSITION THE TUBING AND CUT OFF ANY EXCESS TUBING FOR SORRECT FITTING. 6 SECURE THE TUBING TO THE PARKING BRAKE VALVE AND TO THE BULKHEAD FITTINGS. |
