2-29-2016 |
2.00 |
MANUFACTURE OF FUEL LINES |
FUEL IS ROUTED IN THE EVOLUTION THROUGH A COMBITATION OF ALUMINUM TUBING AND STAINLESS STEEL BRAIDED HOSE. ALUMINUM TUBING IS USED IN THE WING AND FUSALAGE. STAINLESS STEEL BRAIDED HOSE ARE USED FORWARD OF THE FIREWALL. REF TO CHAPTER 2 INTRO TO MATERIALS LAY OUT THE PIING IN ADVANCE OF INSTALLATION. CUT THE PIPING SLIGHTLY LONGER THAN REQUIRED AND TRIM IT TO FIT AT FINAL CONNECTION. BEND THE PIPING AS REQUIRED TO ROUTE AROUND AIRCRAFT COMPONENTS AND SYSTEM PIPING. |
