Date:    2-29-2016
Number of Hours:    4.00
Brief Description:    GASCOLATOR/ FUEL FILTER
THE GASCOLATOR OUNTS TO THE FIREWALL FORWARD.
1 DRILL A 3/4 HOLE IN THE FIRWALL AT THE LOCATION SHOWN IN CHAPTER 23.
2 DECORE THE FIREWALL AROUND THE HOLE A MININMUM OF 1/2 AL ROUND.
3 COMPLETLY PACK TE DECORED AREA WITH FLOX.
4 ALLOW THE FLOX TO CURE A MINIMUM OF 24 HOURS.
5 RE-DRILL THE HOLE.
6 ENSURE THE FIREWALL BLANKET HAS BEEN INSTALLED ON THE FIREWALL PROIR TO INSTALLING THE GASCOLATOR/FUEL PUMP.
7 THREAD THE BULKHEAD FITTING INTO THE INLET PORT OF THE GASCOLATOR AND TIGHTEN IT UNTIL THE O-RING SEATS.
8 INSTALL A WASHER , AND INCERT THE BULKHEAD FITTING THROUGH THE FIRWALL BLANKET AND THE HOLE IN THE FUSALAGE.
9 ORIENT THE GASCOLATOR/ FUEL PUMPWITH THE INDICATOR UP.
10 SECURE THE BULKHEAD FITTING TO THE FIREWALL USING A WASHER AND A NUT THEN INSTALL THE REDUCER.
